How to implement and simulate FFT IP with SimuLink on FPGA (Cyclone V GX starter kit) error vsim-3033
As I understand it, you have some inquiries related to simulating the FFT IP. Sorry for any confusion. Just would like to check if are trying to run simulation in Modelsim? If yes, for your information, you can try to run simulation with the example design using Modelsim Intel FPGA Edition. You may then refer to the example simulation and then cross check to see if you can spot any anomaly with your design.
You can try the following:
1. Open FFT IP
2. Go to Generate -> Generate Example Design
3. Open Modelsim and change directory to the fft_ii_0_example_design\simulation_scripts\mentor
4. source the msim_setup.tcl
5. type "ld" to run the compilation
6. Populate the waveforms and then type "run -all"
Chee Pin
