How to ignore error 18496 (Output ??? too close to PLL clock input)
- 1 year ago
I see the fix has been already published
intel.it/content/dam/support/us/en/programmable/kdb/support/knowledge-center/tools/2016/quartus-16.1-0.01cb-readme.txt
I am glad that the issue has been resolved.
FYI, this is the KDB mentioned.
https://www.intel.com/content/www/us/en/support/programmable/articles/000074027.html
I checked the database, and it appears that this patch was restricted to specific customers with a specific Quartus version at that time and was not typically included in future releases.
This likely explains why you are still seeing the issue in later Quartus releases, and an INI file was created to address the problem.
Since a KDB article has been created and a workaround (using the INI) is available, it is unlikely that this issue will be fixed in future Quartus Standard releases.
Please use the INI file to resolve the issue.
Richard Tan
