John-Philip
1 year agoHow to ignore error 18496 (Output ??? too close to PLL clock input)
Related to: Error (18496): The Output SCLK in pin 26 is too close to PLL clock input in pin 27 Fitter Pin Placement Constraint MAX10 pin too close to PLL clock Pin location is too close to PL...
- 1 year ago
I see the fix has been already published
intel.it/content/dam/support/us/en/programmable/kdb/support/knowledge-center/tools/2016/quartus-16.1-0.01cb-readme.txt
sstrell
1 year agoKDB articles say this was a bug fixed ages ago: https://www.intel.com/content/www/us/en/support/programmable/articles/000074027.html
So it's weird that you're running into it.
Obviously your board is built so you have to use that pin, but can you try moving the LED output location, compile, then move it back and compile again?
You could also try deleting your db and incremental_db folders to do a fresh compile from scratch.
