14 years agoHow to handle the Hold time is violated?
In my design, after analysis in TimeQuest, there are 4 paths that hold time are violated, the slack time is negative. What is normal approach to handle the case that hold time is violated? Than...
14 years ago --- Quote Start --- Yes, I should have mentioned that. That option should always be on. I'm not even sure why it is an option. --- Quote End --- Thanks. In this case, I am lucky that Quartus II help me to remove the hold violated. If both two options be enabled, but the violated still there, could you take a simple example to explain how I can use set_min_delay constraint to remove violated? Hope this will not cost too much time. Thanks very much again.
