LChow3
6 years agoHow to get the equation (expression) from the synthesis tool?
Refer Verilog code attached. After compilation, how can I get the equation (expression) for Y and z from the synthesis tool?
sstrell
6 years agoAre you referring to the logic expression? Check the RTL Viewer under the Tools menu. You can look at logic blocks in that tool based on your RTL code and see the logic implementation.
#iwork4intel
