How to fix "Warning (10030): Net "microcode1.data_a" at MAX10CPU.sv(10) has no driver or initial val
- 1 year ago
You can use synthesis attributes: https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/hdl/vlog/vlog_file_dir_ram_init.htm
I figured it out ... in the IP Catalog expand On Chip Memory, select the type of memory to use, and in the wizard dialogs there's an option to initialize it to a file's contents.
Yes, that's another way to do it with the memory as an IP and a .hex or .mif file. It seemed like you wanted to do it through code inference.
- BobA1 year ago
If there's another way to do this, I love to hear about it.
I didn't really understand your previous comment about using a .dat file. The .mem file I'm using is in the format accepted by $readmemh.
- sstrell1 year ago
I've always used .dat for this. I've never actually heard of .mem. This article uses .txt actually: https://fpgacoding.com/test-bench-data-files-in-verilog/
- BobA1 year ago
It's just the extension. I know the file's contents are in $readmemh's format.
The bigger concern is that the 'initial' block doesn't get synthesized. But is there another way to initialize memory in the synthesized Verilog?
