SMatl
6 years agoHow to fix BDF Text Scaling Bug when Windows Scaling active?
Since years and versions, Quartus fails on creating correct Text-Frame-Sizes on BDF Files when Windows-Scaling (125%) ist active. When (or how) will this be fixed? It is a catastrophic pain to guess ...
KhaiChein_Y_Intel
6 years agoHi,
Yes. This problem is documented in this KDB https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/spr360409.html
Platform Designer is different from BDF schematic entry. Platform Deisgner is a system integration tool in the Intel® Quartus® Prime software. The Platform Designer saves significant time and effort in the FPGA design process by automatically generating interconnect logic to connect intellectual property (IP) functions and subsystems. You may also create a custom IP using Platform Designer.
KhaiY
