8 years agoHow to ensure multiplexer priority levels coded in VHDL
Hi, How to ensure a value "CAFE" on the register Reg_In with the RTL code:Reg_In <= X"CAFE" when A = '1' else In_1 when K = '1 else In_2 when L...
8 years agoQuartus will only synthesise what you write.
The snippet you posted says that Reg_in will be x"CAFE" when A = 1. If you are having problems, then I suggest there is a problem in the design somewhere. Where are you seeing the problems? simulation, or on the board? Without the whole code, there isnt much more I can say.
