18 years agoThe document you're using talks about 3 reference designs at the end, which you should be able to download from the same place you downloaded the AN367 document. The second one should be the one you're looking for.
Beware in reconfiguring though. Making changes to anything other than the post-scale counter or the phase will result in a PLL loss. That's what I'm currently trying to figure out is how to reacquire the lock. Perhaps someone will have an answer for that.
