OHarb1
6 years agoHow to disable a specific warning
I get megabytes of this warning. What does it mean? Can I disable it? Warning (14320): Synthesized away node "top|fiddlybob|memory_rtl_1|auto_generated|q_b[4078]" File: /workspace/[deleted]/tmp-c...
- 6 years ago
There seems to be noway to do it without GUI.
We do have message suppression manager . It is a form of *.sff that recognized by the quartus. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii52012.pdf but it GUI to handle the import and export.
looking into quartus_sh --qhelp -> report, it seems does not have this feature as well.
I will file an enhancement feature to our developer.
KennyT_altera
6 years agoThis means that this node is not connecting to anythings. you will have to check the connection in your design.
You can suppress message by right click on the messages -> suppress
OHarb1
6 years ago- The warning is in code generated by Quartus: "altsyncram_v8j1.tdf". I can't connect the dots from what I did to getting this warning.
- I'm not using the user-interface, this is from a build server. I would like to suppress the files from the build log. Is there an option or tcl command to stop this warning from appearing during P&R?
