Sabrina23
1 year agoHow to design divider circuit data path unit in Quartus II?
Hi I'm having problem to design divider circuit using Quartus II Lite using schematic design. Most of the data path unit design I found only in VHDL code. But, I am required to design in schematic di...
FvM
1 year agoHi,
the answer really depends on your exercise problem specification. If you are required to make a schematic (basically a structural design) comprised of elementary logic elements only, then have to build it from the scratch. The HDL code or a flow diagram of non-restoring algorithm can be used as a template.
A relative compact Verilog implementation copied from Stratix Cookbook is appended below. Question is which elementary logic/arithmetic functions are taken as granted and which have to be designed by yourself?
Frank
