9 years agohow to create matrix in VHDL
Hi guys! I am trying to create a matrix or an array. 4 columns and 2 rows. Is my code correct?
type row_t is array(0 to 3) of std_logic_vector(7 downto 0);
type matrix_t is array(0 to 1, 0 to 3) of std_logic_vector(7 downto 0); Also I want to assign a variable to the first column? what is the syntax for this? thank you.4 Replies
Yes, it is a matrix
2d matrices cannot be slices, so you need to assign individual elements. You could build it with 1d arrays, which can be sliced to apply an entire row. - Altera_Forum
what is the syntax for slicing a row?
like this (not possible with 2d array:
op <= matrix(a to b); or op <= matrix(b downto a); You really need to try some code yourself - this is very basic VHDL fundamentals you should be learning yourself from a book or from a tutorial. - Altera_Forum
--- Quote Start --- Yes, it is a matrix 2d matrices cannot be slices, so you need to assign individual elements. You could build it with 1d arrays, which can be sliced to apply an entire row. --- Quote End --- Excuse me for being pedantic but the OP asked how to assign a variable to the first column. Which is as tedious for a 1Dx1D as for a 2D array?
