How to constraint max skew between two net or balance the delay between two net?
- 4 years ago
You may refer to this video on how to constraint your design: https://www.youtube.com/watch?v=ggWxledaBFg
Nurina
I don't quite understand the design, could you provide a block diagram?
Nurina
- NuvKFC4 years ago
Contributor
Hi Nurina
Thank you, Nurina, very much.
The design is as follow picture.
PAD1 is used as a clock of module A.
PAD2 is used as a data of module A. And PAD have a multi function. It uses PAD2 as a clock of module B.
Some flipflop in the module A use data_a as a clock.
So, I create a clock on node data_a.
I don't want to create a clock for data_a on PAD2 because it will cause many false paths.
Due to that, I constraint data_a on the node data_a of module A.
Clock domain data_a and Clock domain clock_a have data crossing.
So, the clock from the data_a and the clock from clock_a is in the same clock group.
(Designer tell me that clock domain data_a and clock domain clock_a should be in the same clock group.)
The detail of constraint of the design is as follow.
Design:
Constraint example:
create_clock clock_a [get_port Module_A|clock_a]
create_clock data_a [get_port Module_A|data_a]
create_clock clock_b [get_port Module_B|clock_a]
create_clock_groups -asynchronous -group [clock_b ]
-group [clock_a data_a]
After Fitter, the net from PAD1 to clock_a and net from PAD2 to data_a become as follow picture.
The delay of the path from PAD1 to clock_a (Path1) and the path from PAD2 to data_a (Path2) is unconstrainted.I add the constraint as follow for these two path.
Constraint:
set_net_delay -max 5.0 -from PAD1 to clock_a
set_net_delay -min 0.0 -from PAD1 to clock_a
set_net_delay -max 5.0 -from PAD1 to data_a
set_net_delay -min 0.0 -from PAD1 to data_a
And I want to balance the delay between the path from PAD1 to clock_a (Path1) and the path from PAD2 to data_a (Path1) for the min clock skew between clock domain clock_a and clock domain data_a.
But I'm confused how to minimize the clock skew.
The one way I think is to balance the skew of these two paths.
Then I'm confused how to balance the skew of these two paths.
