vlad
6 years agoHow to constrain the delays from ports to combinational block?
Hi! I'm trying to transmit data from one FPGA to another (DE1-SoC Cyclone V boards). The method I'm using is to have two wires, such that a transition on one wire means that a 0 is transmitted, and...
sstrell
6 years agoCan you post your .sdc? Also make sure that your .sdc file has been added to the Timing Analysis settings. Those are huge delays so something's fishy with either your constraints or your design.
#iwork4intel
vlad
6 years agoHi, Thank you for the reply.
Here is my SDC file:
create_clock -name input_clock -period 20.000 [get_ports {CLOCK_50}]
create_clock -name rx_xor -period 4.0 [get_pins {rx_gen_clock|combout}]
derive_pll_clocks
set_false_path -from [get_clocks {input_clock}] -to [get_clocks {u_tx_pll|tx_pll_inst|altera_pll_i|general[0].gpll~PLL_OUTPUT_COUNTER|divclk u_tx_pll|tx_pll_inst|altera_pll_i|general[0].gpll~FRACTIONAL_PLL|vcoph[0]}]
set_false_path -from [get_registers *async_rx*] -to [get_registers *error_counter*]
set_net_delay -from [get_registers *async_rx*] -to [get_registers *error_counter*] -max -get_value_from_clock_period dst_clock_period -value_multiplier 0.8
set_max_delay -from [get_ports {RX[0] RX[1]}] -to [get_pins {rx_gen_clock|combout}] 8
set_min_delay -from [get_ports {RX[0] RX[1]}] -to [get_pins {rx_gen_clock|combout}] 7.5Report data path:
report_path -from [get_ports {RX[1] RX[0]}] -to [get_pins {rx_gen_clock|combout}] -npaths 100 -panel_name {Report Path} -multi_corner
Delay From To
7.512 RX[0] rx_gen_clock|combout
5.627 RX[1] rx_gen_clock|comboutAnd the paths in chip planner:
That essentially what I want to do (I could make the tx_pll clock 200 Mhz by using ddo registers for the outputs)
Btw, I have synthesized it once and it kinda worked, so I could transmit data at 400 Mbps between two FPGAs (sending just an incrementing counter and checking on the other side that I got the right value),
but it's too unreliable especially if I slightly change the code then everything changes. Thanks
