14 years agoHow to connect LAN91C111 in Qsys?
Hi all,
I got confused about connecting LAN91C111 controller in Qsys. I use the Generic Tri-State Controller in Qsys, and choose the LAN91C111 Interface preset. The problem is the clk interface of the LAN91C111 controller. Because the frequency of the clock that Nios used is 100MHz, but the frequency of the clock of the LAN91C111 chip is 50MHz; should I use the Avalon-MM Clock Crossing Bridge, or add an Avalon ALTPLL into Qsys, and connect the Avalon ALTPLL and LAN91C111 controller? Regards, feng
