How to change a library refence in modelsim?
Hello
I am trying to calculate a natural logarithm in VHDL.
Compilation for my board works properly, simulation does not:
** Error: (vsim-3732) C:/FpgaProjects/Q17/DE10_STD_PSD_CALC_VHDL/FloatLn.vhd(5924): No default binding for component instance 'squarer'.
# The following component port is not on the entity:
# sclr
# Time: 0 ps Iteration: 0 Instance:
The component declaration can be found in altera_mf_components. vhd. This file has multiple versions on my sytem.
- version 1: resides in c:\intelfpga_lite\17.1\modelsim_ase\altera\vhdl\src\altera_mf
- version 2: resides in c:\intelfpga_lite\17.1\quartus\libraries\vhdl\altera_mf
- version 3: resides in c:\intelFPGA_lite\17.1\quartus\eda\sim_lib
The component declaration of version 2 contains a declaration of the component with an SCRL port, the others do not.
First i tried to remove the sclr port from the component interface declaration in altera_mf_components.vhd. I saved the file and recompiled my application => The error remained?
(sclr is not used in the implementation of the component)
Q1: do I need to recompile the library as well ? And if so how ? Compiling the libary itself (right click + recompile) => "Error: Please check the error log for more details". I have not idea where the error log can be found. Modelsim does not provide a file name and the error log is not in the source file directory of altera_mf? Double click on the red messages in the output window give no link to the error file. I also tried library / update on the function I need => Error "data_width has not been given a value".
Q2: I found a link to an identical problem with the altera altsquare mega function. There a solution was presented in the fact that i need to refer to the source codes in directory version 3. So my question is, how to do this?
The way to go seems Library/Edit library mapping. However the path referenced to is "$MODEL_TECH/../altera/vhdl/altera_mf" What excatly do i have to do to make the proper changes? If I change the reference of altera_mf to directory 3, I get "altera_mf (unavailable)" in the library list, so no solution this way.
Help would be appreciated.
Johi.
- Vicky1
Hi Johi,
"hi Johi,
Can you please check the each & every port & ports type of the component instance 'squarer' & corresponding entity?
Especially sclr port."
It was my previous post.
The issue is squaring operation cannot be used together with synchronous clear signal for LPM_MULT.
It should not be on port list.
Refer below code from FloatLn.vhd file & try to simulate, here port "sclr" is commented in COMPONENT & remove it from Entity as well if you can.
COMPONENT altsquare GENERIC ( DATA_WIDTH : NATURAL; PIPELINE : NATURAL; REPRESENTATION : STRING := "UNSIGNED"; RESULT_ALIGNMENT : STRING := "LSB"; RESULT_WIDTH : NATURAL; lpm_type : STRING := "altsquare" ); PORT ( aclr : IN STD_LOGIC := '0'; clock : IN STD_LOGIC := '1'; data : IN STD_LOGIC_VECTOR(DATA_WIDTH-1 DOWNTO 0); ena : IN STD_LOGIC := '1'; result : OUT STD_LOGIC_VECTOR(RESULT_WIDTH-1 DOWNTO 0) --sclr : IN STD_LOGIC := '0' ); END COMPONENT; squarer : altsquare GENERIC MAP ( DATA_WIDTH => 13, PIPELINE => 1, REPRESENTATION => "UNSIGNED", RESULT_ALIGNMENT => "MSB", RESULT_WIDTH => 14 ) PORT MAP ( aclr => aclr, clock => clock, data => squarerIn, ena => clk_en, result => wire_squarer_result );Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
- JOHI
Contributor
Hello Vicky, Hello Abraham, Hello Tricky,
Thanks for your reactions: Your proposals are correct workarounds. However, every time this ALT_LOG is generated, manual correction will be necessary, so I share Abraham's conclusion.
As of Vicky's request/remark: I my initial request/detailed analysis referes to the fact that the "sclr" port was in some component definitions & some others it was not (be it all Altera lib or Altera IP code). That even within 1 lib directory, there are differences between component declarations & implementations. So I thought rechecking was not necessary, hence the misunderstanding.
But my inital queston remains still on the table: (I cannot help it :)): To do what is described in (be it an alternative solution for the issue or not) :
To perform functional and timing simulations, you must use the altera_mf.v library located in the <Quartus II installation directory>\eda\sim_lib directory. For VHDL, you must use the altera_mf.vhd library located in the <Quartus II installation directory>\eda\sim_lib directory. The VHDL component declaration file is located in the altera_mf_components.vhd library in the <Quartus II installation directory>\eda\sim_lib directory.
How do you do this ?
I select the altera_mf.vhd in Modelsim after launching it via Quartus. I click right, then I select "Edit Library Mapping", then "Browse", then I select a directory "C:/intelFpga_lite/17.1/quartus/eda/sim_lib."
The result is: altera_mf (unavailable) in the Library window?
So indeed I have a workaround, but I still wonder how does one do what is specified in the Intel/Altera web page?
Do you need to change the complete list of lib references or only reference?
Johi.
