JOHI
Contributor
8 years agoHow to change a library refence in modelsim?
Hello I am trying to calculate a natural logarithm in VHDL. Compilation for my board works properly, simulation does not: ** Error: (vsim-3732) C:/FpgaProjects/Q17/DE10_STD_PSD_CALC_VHDL/FloatLn.v...
Vicky1
8 years agoHi Johi,
"hi Johi,
Can you please check the each & every port & ports type of the component instance 'squarer' & corresponding entity?
Especially sclr port."
It was my previous post.
The issue is squaring operation cannot be used together with synchronous clear signal for LPM_MULT.
It should not be on port list.
Refer below code from FloatLn.vhd file & try to simulate, here port "sclr" is commented in COMPONENT & remove it from Entity as well if you can.
COMPONENT altsquare
GENERIC
DATA_WIDTH : NATURAL;
PIPELINE : NATURAL;
REPRESENTATION : STRING := "UNSIGNED";
RESULT_ALIGNMENT : STRING := "LSB";
RESULT_WIDTH : NATURAL;
lpm_type : STRING := "altsquare"
PORT
aclr : IN STD_LOGIC := '0';
clock : IN STD_LOGIC := '1';
data : IN STD_LOGIC_VECTOR(DATA_WIDTH-1 DOWNTO 0);
ena : IN STD_LOGIC := '1';
result : OUT STD_LOGIC_VECTOR(RESULT_WIDTH-1 DOWNTO 0)
--sclr : IN STD_LOGIC := '0'
END COMPONENT;
squarer : altsquare
GENERIC MAP (
DATA_WIDTH => 13,
PIPELINE => 1,
REPRESENTATION => "UNSIGNED",
RESULT_ALIGNMENT => "MSB",
RESULT_WIDTH => 14
PORT MAP (
aclr => aclr,
clock => clock,
data => squarerIn,
ena => clk_en,
result => wire_squarer_result
);Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
