JOHI's avatar
JOHI
7 years ago
How to change a library refence in modelsim?
Hello
I am trying to calculate a natural logarithm in VHDL.
Compilation for my board works properly, simulation does not:
** Error: (vsim-3732) C:/FpgaProjects/Q17/DE10_STD_PSD_CALC_VHDL/FloatLn.vhd(5924): No default binding for component instance 'squarer'.
# The following component port is not on the entity:
# sclr
# Time: 0 ps Iteration: 0 Instance:
The component declaration can be found in altera_mf_components. vhd. This file has multiple versions on my sytem.
The component declaration of version 2 contains a declaration of the component with an SCRL port, the others do not.
First i tried to remove the sclr port from the component interface declaration in altera_mf_components.vhd. I saved the file and recompiled my application => The error remained?
(sclr is not used in the implementation of the component)
Q1: do I need to recompile the library as well ? And if so how ? Compiling the libary itself (right click + recompile) => "Error: Please check the error log for more details". I have not idea where the error log can be found. Modelsim does not provide a file name and the error log is not in the source file directory of altera_mf? Double click on the red messages in the output window give no link to the error file. I also tried library / update on the function I need => Error "data_width has not been given a value".
Q2: I found a link to an identical problem with the altera altsquare mega function. There a solution was presented in the fact that i need to refer to the source codes in directory version 3. So my question is, how to do this?
The way to go seems Library/Edit library mapping. However the path referenced to is "$MODEL_TECH/../altera/vhdl/altera_mf" What excatly do i have to do to make the proper changes? If I change the reference of altera_mf to directory 3, I get "altera_mf (unavailable)" in the library list, so no solution this way.
Help would be appreciated.
Johi.
  • Vicky1's avatar
    Vicky1
    Hi Johi,
    "hi Johi,
    Can you please check the each & every port & ports type of the component instance 'squarer' & corresponding entity?
    Especially sclr port."
    It was my previous post.
    The issue is squaring operation cannot be used together with synchronous clear signal for LPM_MULT.
    It should not be on port list.
    Refer below code from FloatLn.vhd file & try to simulate, here port "sclr" is commented in COMPONENT & remove it from Entity as well if you can.
     COMPONENT  altsquare
    	 GENERIC
    		DATA_WIDTH	:	NATURAL;
    		PIPELINE	:	NATURAL;
    		REPRESENTATION	:	STRING := "UNSIGNED";
    		RESULT_ALIGNMENT	:	STRING := "LSB";
    		RESULT_WIDTH	:	NATURAL;
    		lpm_type	:	STRING := "altsquare"
    	 PORT
    		aclr	:	IN STD_LOGIC := '0';
    		clock	:	IN STD_LOGIC := '1';
    		data	:	IN STD_LOGIC_VECTOR(DATA_WIDTH-1 DOWNTO 0);
    		ena	:	IN STD_LOGIC := '1';
    		result	:	OUT STD_LOGIC_VECTOR(RESULT_WIDTH-1 DOWNTO 0)
    		--sclr	:	IN STD_LOGIC := '0'
    	 END COMPONENT;
    squarer :  altsquare
    	  GENERIC MAP (
    		DATA_WIDTH => 13,
    		PIPELINE => 1,
    		REPRESENTATION => "UNSIGNED",
    		RESULT_ALIGNMENT => "MSB",
    		RESULT_WIDTH => 14
    	  PORT MAP (
    		aclr => aclr,
    		clock => clock,
    		data => squarerIn,
    		ena => clk_en,
    		result => wire_squarer_result
    Best Regards
    Vikas Jathar
  • JOHI's avatar
    JOHI
    Hello Vicky, Hello Abraham, Hello Tricky,
    Thanks for your reactions: Your proposals are correct workarounds. However, every time this ALT_LOG is generated, manual correction will be necessary, so I share Abraham's conclusion.
    As of Vicky's request/remark: I my initial request/detailed analysis referes to the fact that the "sclr" port was in some component definitions & some others it was not (be it all Altera lib or Altera IP code). That even within 1 lib directory, there are differences between component declarations & implementations. So I thought rechecking was not necessary, hence the misunderstanding.
    But my inital queston remains still on the table: (I cannot help it :)): To do what is described in (be it an alternative solution for the issue or not) :
    https://www.intel.com/content/www/us/en/programmable/quartushelp/13.1/mergedProjects/hdl/mega/mega_file_altsquare.htm
    To perform functional and timing simulations, you must use the altera_mf.v library located in the <Quartus II installation directory>\eda\sim_lib directory. For VHDL, you must use the altera_mf.vhd library located in the <Quartus II installation directory>\eda\sim_lib directory. The VHDL component declaration file is located in the altera_mf_components.vhd library in the <Quartus II installation directory>\eda\sim_lib directory.
    How do you do this ?
    I select the altera_mf.vhd in Modelsim after launching it via Quartus. I click right, then I select "Edit Library Mapping", then "Browse", then I select a directory "C:/intelFpga_lite/17.1/quartus/eda/sim_lib."
    The result is: altera_mf (unavailable) in the Library window?
    So indeed I have a workaround, but I still wonder how does one do what is specified in the Intel/Altera web page?
    Do you need to change the complete list of lib references or only reference?
    Johi.
