9 years agoHow to avoid delay
Hello everyone,
My problem is that i have an output available at a current clock cycle and i need to be read at the same clock cycle by another register. My top level entity is where i instantiate components but the problem is exactly in this code :library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_signed.all;
use ieee.math_real.all;
library std;
use work.MIN.all;
entity labeling is
generic(
LABEL_WIDTH : integer;
PIX_WIDTH : integer );
port(
clk_proc : in std_logic;
reset_n : in std_logic;
------------------------- in flow -----------------------
in_data : in std_logic;
in_fv : in std_logic;
in_dv : in std_logic;
p00u : in std_logic;
p01u : in std_logic;
p02u : in std_logic;
p10u : in std_logic;
p11u : in std_logic;
p12u : in std_logic;
------------------------ out flow -----------------------
out_fv : out std_logic;
out_dv : out std_logic;
------------------------ labels --------------------------
north_LABEL , west_LABEL : in std_logic_vector ((LABEL_WIDTH-1) downto 0);
north_west_LABEL , north_ouest_LABEL : in std_logic_vector ((LABEL_WIDTH-1) downto 0 );
current_LABEL , Label_to_merge , Label_instead : out std_logic_vector ((LABEL_WIDTH - 1) downto 0);
need_to_merge, need_to_resolve: out std_logic ;
number_of_object : out natural
end labeling;
architecture arch of labeling is
------ ------------------signaux pour les étiquettes-------------------------------------------------------------------------------
signal north ,west : integer :=0;
signal north_ouest , north_west : integer:=0;
signal curr : integer;
signal L_to_merge , L_instead : integer:=0 ;
signal merge , resolve : std_logic;
Begin
north <= to_integer ( signed( '0' & (north_LABEL)));
west <= to_integer ( signed( '0' & (west_LABEL)));
north_west <= to_integer ( signed( '0' & (north_west_LABEL)));
north_ouest <= to_integer ( signed( '0' & (north_ouest_LABEL)));
-------------------------------------- labeling---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
process(clk_proc,reset_n)
variable new_label : integer:= 1 ;
variable n_objects : integer := 0 ;
begin
if (reset_n = '1' )then curr <=0;
elsif (rising_edge(clk_proc))then
if ((in_fv and in_dv )='1' ) then
if (in_data= '0')then
curr <= 0;
merge<='0';
else
if (p01u = '1') then
curr <= north;
merge<='0';
else
if (p02u='1') then
if (p00u ='1') then
merge <='1';
curr<= minimum(north_west,north_ouest);
L_to_merge <= maximum (north_west,north_ouest);
L_instead <= minimum(north_west,north_ouest);
else
if (p10u ='1') then
merge <='1';
curr<= minimum(west,north_ouest);
L_to_merge <= maximum(west,north_ouest);
n_objects := n_objects - 1 ;
else
curr<= north_ouest;
merge<='0';
end if;
end if;
else
if (p00u ='1') then
curr <= north_west;
merge<='0';
else
if (p10u ='1') then
curr<= west;
merge<='0';
else
curr<= new_label;
new_label:= new_label+1;
n_objects := n_objects + 1 ;
merge<='0';
end if;
end if;
end if;
end if;
end if;
if (merge='1' and north_ouest=minimum(north_west,north_ouest)) then
resolve<='1';
else
resolve<='0';
end if;
if merge='1' then
end if;
end if;
end if;
report "The number of objects is " & integer'image(n_objects);
number_of_object<=n_objects;
end process;
current_LABEL <= std_logic_vector(to_signed(curr,LABEL_WIDTH));
Label_to_merge<= std_logic_vector(to_signed(L_to_merge,LabEL_WIDTH));
Label_instead<= std_logic_vector(to_signed(L_instead,LabEL_WIDTH));
need_to_merge<=merge;
need_to_resolve<= '1' when merge='1' else
'0';
end arch; Where the signal current_LABEL takes always the previous values of North, North_ouest, North_est and west instead of the current values . Ps: The North, North_ouest, North_Est and West values are provided by another module.12 Replies
FPGAs are good at parrellel logic. If you need Lx at different places, then create copies of it.
Thank you so much for your help.
