How to assign to HPS_UART_RX pins?
You can open in the Assignments Tab in Quartus, then select Pin Planner, then you may assign pins in the Location Tab in the table at the bottom.
May I know which Quartus version you are working on?
Regards.
hi,
thx for your response. Like I said, I can't select them. Apparently we are talking about HPS GIOs (pic is from the handbook), which I can't assign to my inputs and outputs in my VHDL project. At least not like I used to do it with the pin planner.
In a demo on the CD I found a Verilog project, which managed to assign these HPS GIOs (HDMI, DDR, USB, etc). In the manuals I found this:
The board provides 25 HPS GPIOs (3.3V), which are connected directly to the Cyclone V SoC HPS. [...] Each HPS I/O corresponds to different HPS peripheral controllers, users can set these peripheral controllers through the Qsys built in
Quartus software.
So I tried Qsys, but just had no luck with it. Also the demo project didn't add any components with Qsys (as far as I can tell).
I'm working with Quartus 17.1
