How to assign each bus bit from a schematic to board pin?
@RNeto2 , unless I'm completely misunderstanding you, it sounds like you are trying to access the FPGA IO pins via a Verilog program. But nothing you've provided allows you to do that. The top level HDL program will not have a port map as in the code you've provided. Instead, you tell it the pins in a constraint file (or via pin planner as @sstrell ). But your "schematic" does not list the FPGA pins. You need to trace it back to where it connects to the FPGA.
I'm assuming you are new to FPGA's ? It's too much to explain in a forum post. Altera has some outstanding free training found here:
https://www.intel.com/content/www/us/en/programmable/support/training/catalog.html
The "Become an FPGA Designer in 4 hours" is great as are most of the others.
