DCack
6 years agoHow to add custom component in Platform Designer that instantiates library IP?
I have a Platform Designer system. It contains a lot of components, both from the Intel libary and custom ones designed by myself. Normally, I use the following procedure to import my custom compone...
SyafieqS
6 years agoCould you elaborate more how you solve the issue? Some sharing here :)
- DCack6 years ago
In summary:
Problem: you have your own IP which contains both custom HDL modules and IP generated by Quartus megawizard. How to import that IP to the Platform Designer to make it visible as a component? Which files to add during "Add. component..." process?
Solution: In GUI, import all your HDL files along with *.qip file of generated components by megawizard. It produces some warnings about missing files duing whole design synthesis, but after all it works.
Damian
