DCack
6 years agoHow to add custom component in Platform Designer that instantiates library IP?
I have a Platform Designer system. It contains a lot of components, both from the Intel libary and custom ones designed by myself. Normally, I use the following procedure to import my custom compone...
DCack
6 years agoFinally it turned out, that adding QIP file works ok. Although there are synthesis tool warnings about missing some files, but after implementation my IP is synthesized correctly.
