DCack
6 years agoHow to add custom component in Platform Designer that instantiates library IP?
I have a Platform Designer system. It contains a lot of components, both from the Intel libary and custom ones designed by myself. Normally, I use the following procedure to import my custom compone...
SyafieqS
6 years agoHi Damian,
Try to use .ipx file for managing custom libraries of platform designer component through multi-layered serach path. You can create the ipx file refer to link below for detail. In the .ipx file you can specify where directory can search for your custom IP component.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-platform-designer.pdf
