imarz1
6 years agoHow does limited time .SOF file work ?
I am new, and I created simple program that turns LED ON/OFF via one switch on board. This is done via NIOS II. I then created program in Eclipse to do that. I programmed it, and it all worked fine a...
SyafieqS
6 years agoHi Imad,
During Intel FPGA IP Evaluation Mode, the Compiler only generates a time-limited device programming file (<projectname>_time_limited.sof) that expires at the time limit. Yes unfortunately it is one-time limited only and if you want to use your code after the evaluation time has expired, you need to buy the IP core implemented in your programming - otherwise you won't be able to program your FPGA. You can refer to link below for details
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an320.pdf
