BHunt11
6 years agoHow do I report powered-down transceivers and PLLs in Quartus Prime Standard?
I have an issue which looks like an xcvr_fpll_a10_0 may not be powered or is shut down. How can I confirm that all the PLLs are in fact powered on in Quartus?
BHunt11
6 years agoDo the transceivers operate in any mode without the CLKUSR present? For example, can I put the PCS or PMA into loopback? That is, all RX receiver data is looped out the TX transmitter.
In this way, I could test the circuit in and out of the transceiver, before I fabricate new boards.
BHunt11
6 years agoThis is the looback mode I want to enable: Fig 236: Reverse Serial Loopback Path/Pre CDR, in UG-01143. May be called "diagnostic loopback".
