BHunt11
6 years agoHow do I report powered-down transceivers and PLLs in Quartus Prime Standard?
I have an issue which looks like an xcvr_fpll_a10_0 may not be powered or is shut down. How can I confirm that all the PLLs are in fact powered on in Quartus?
Deshi_Intel
6 years agoHI,
Sorry, transceiver calibration is relying on clkusr as the clock source. We don't have alternate option to switch to FPGA internal clocking source.
I am afraid I need to request you to fix your board connection on clkusr pin connection.
dlim
BHunt11
6 years agoDo the transceivers operate in any mode without the CLKUSR present? For example, can I put the PCS or PMA into loopback? That is, all RX receiver data is looped out the TX transmitter.
In this way, I could test the circuit in and out of the transceiver, before I fabricate new boards.
- BHunt116 years ago
This is the looback mode I want to enable: Fig 236: Reverse Serial Loopback Path/Pre CDR, in UG-01143. May be called "diagnostic loopback".
