16 years ago
How do I connect two vhdl files
If I have two vhdl files for two blocks and I want to connect them to each other what do I do?
    You can use a block diagram file to connect them visually...
    In quartus, new file : block diagram file
    You can also make a third VHDL file an with PORT MAP you can connect them...
    But I am a beginner and I'm not sure...
    thx for your reply
    I have to make sure because I'm short in time
    I saw they add a library file and use it in other files
    you dont even need a component decalration. Its alot safer to just use direct instantiation:
    my_inst : entity work.my_ent --this is the direct instantiation part
    port map (
    Using this method, errors with the port map are picked up by the compiler instead of the simulator/synthesis (ie. you find errors alot quicker.)
    I dont understand
    I make this port map in third file or in 1 of the files
    You better do it in 3rd vhdl file.
    This 3rd file will have proper input/outputs and be dedicated to declaring the other two modules inside as components and then connecting inputs/outputs of these internal two modules together and with top level inputs/outputs. i.e. just structural vhdl(nothing else).
