16 years agoyou dont even need a component decalration. Its alot safer to just use direct instantiation:
my_inst : entity work.my_ent --this is the direct instantiation part port map ( ); Using this method, errors with the port map are picked up by the compiler instead of the simulator/synthesis (ie. you find errors alot quicker.)
