8 years agoHow declare ALM synchronous signal (enable, sload, sclear) in vhdl
Hello. The basic cell in Intel FPGA have a wonderful architecture, including dedicated synchronous signals as enable, sload and sclear. However, describe the use of this resources is not easy in v...
8 years agoYou can access a complete template for all secondary control signals using the Edit menu in the Quartus text editor. But here is a similar complete template. Just remove the signals you don't want to use:
ARCHITECTURE behavior OF dff IS
BEGIN
PROCESS(clk, aclr, apre, aload, adata)
BEGIN
IF aclr = '1' THEN
q <= '0';
ELSIF apre = '1' THEN
q <= '1';
ELSIF aload = '1' THEN
q <= adata;
ELSIF rising_edge(clk) THEN
IF ena = '1' THEN
IF sclr = '1' THEN
q <= '0';
ELSIF sload = '1' THEN
q <= sdata;
ELSE
q <= d;
END IF;
END IF;
END IF;
END PROCESS;
END ARCHITECTURE behavior;
