CJuni1
6 years agoHow can I install OpenCL FPGA SDK Prime Pro 16.0?
I'm trying to install aocl compiler for HARP environment (Arria10), I followed the instructions and whenever I try to compile a project it happens the following error: aoc: This release of Altera SD...
MEIYAN_L_Intel
6 years agoHi,
I am sorry for misunderstanding to the problem occurred.
The problem might be due to the environment variable for Quartus is not set correctly.
You can refer to Chapter 2.5 (Windows) or Chapter 3.5 (Linux) to set and point to the Quartus Pro version with command"QUARTUS_ROOTDIR_OVERRIDE" as link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf
- CJuni16 years ago
I have set this variable, but the aoc compiler always open the standard version. If I try to open manually, it opens the pro version. I have tried to change the script to open the pro version, but it didn't work either. Is there any way to change that?
