How can I delete old files of a Modelsim's simulation?
I have been installed Quartus Prime Lite (ver19.1) and its Modelsim Starter Edition, and started learning Verilog recently. After doing several simulations (drawing waveforms by Modelsim Simulation) I noticed my Hard drive (C) has decreased its free space quickly (several GBs a day) although I put my Verilog's project in Drive D. I don't know what causes this. I think Modelsim created those files for simulation but I dont know where they are.
- RichardT_altera
The simulation files are located at your project directory.
To check what files take up the hard drive space most: Go to Storage and check for any files that may have consumed a lot of your disk space.
p.s. Don’t forget to Reply, and Select the Best Solution. :)
- Cuong_Nguyen
Thank you for your support, I have found a dump file (about 2.5GB) and delete it. Now my disk space is 70GB free, I will observe those next days to see whether or not this problem happens again.
- RichardT_altera
Is everything fine? Do you need further help?
- Cuong_Nguyen
I think the problem has been solved now because my disk space is ranging around 70GB only while I am still using Quartus and ModelSim. Thank you for your support!
