KOber
6 years agoHow can I change an I/O pin's pull_up value without re-synthesizing the design?
I need to change whether or not there are weak pull_ups on an FPGA's I/O pin but don't have the privilege of re-compiling the whole design. A new gateware file would need to be created, but since...
ShafiqY_Intel
6 years agoHi KOber,
Apparently, pull up the I/O without re-synthesizing the design is not possible.
You can only pull up it using Pin Planner or Pin assignment. Then you have to compile it to create a new bit stream.
- KOber6 years ago
ShafiqY_Intel,
Can you put in an Arria 10 feature request for the ability to add pull ups to I/O without re-synthesizing the design, and provide me with the change request number?
Thank you
- KOber6 years ago
ShafiqY_Intel,
What is the Change Request Number for this feature request?
