10 years agoHigh-impedance state when simulate FIFO IP core using Modelsim altera
I have generated the FIFO IP-core Using Quartus 12.1 ,and simulated it with Modelsim-altera starter edition. The top-test file and the incentives are as follows:
//---------------------top_test--------------------------------------------------------------------- `timescale 1ns/1ns module top_test( output [31:0] q , output empty, output full ); wire [31:0] data; wire data_val; reg rd_req; reg data_val_0,data_val_1; always@(posedge clk) data_val_0<=data_val; always@(posedge clk) data_val_1<=data_val_0; always@(posedge clk) rd_req <= data_val_1; clk_reset_gen clk_reset_gen( .clk (clk), .reset_n (reset_n) ); data_gen data_gen( .clk (clk ), .reset_n (reset_n ), .data (data ), .data_val (data_val) ); fifo_bbbb fifo_bbbb( .aclr (~reset_n), .clock (clk), .data (data), .rdreq (rd_req), .wrreq (data_val), .empty (empty), .full (full), .q (q) ); endmodule //---------------------clk_reset_gen------------------------------------------------------------------------ `timescale 1ns/1ns module clk_reset_gen( output reg clk, output reg reset_n ); initial begin clk =1'b0; reset_n =1'b0;# 1000 reset_n =1'b0;# 10000 reset_n =1'b1; end always# 10 clk = ~clk; endmodule //----------------------data_gen----------------------------------------------------------------------- module data_gen( input clk, input reset_n, output [31:0] data, output data_val ); reg [8:0] counter; always@(posedge clk or negedge reset_n)begin if(~reset_n) counter<='b0; else counter<=counter+1'b1; end assign data = {counter[7:0],counter[7:0],counter[7:0],counter[7:0]}; assign data_val = counter[8]; endmodule http://www.alteraforum.com/forum/attachment.php?attachmentid=11341&stc=1 //-----------end---------------------------------------------------------------- I have compiled the files :test_top.v,clk_reset_gen,data_gen,fifo_bbbb.v,220model,altera_mf into the same library,but all the output signals are high-impedance state.When I starting the modelsim_altera through the Nativelink to simulate ,I got the same result . Please help me ,thank you very much ! !1 Reply
- DNguy4
Did you find out the cause of this? I see something similar with my design.
