AD0001
6 years agoHi, While trying to compile the project in Altera_quartus linux environment quartus_map fails abruptly with the following message. > Running quartus_map input in flex scanner failed. What is the reason behind this failure ?
Running quartus_map input in flex scanner failed mv: cannot stat '/home/nis/abd/svn/hw/trunk/pd/fpgas/cfpga/par/cfpga.map.rpt': No such file or directory ERROR: quartus_map exited with Non-Zero ...
AD0001
6 years agoHi,
Please find the system details below.
- OS type and version
16.04.1-Ubuntu x86_64bit
2. Your machine spec
product: Intel(R) Xeon(R) CPU E5-2643 v4 @ 3.40GHz
vendor: Intel Corp.
physical id: 1
bus info: cpu@0
capacity: 3700MHz
width: 64 bits
3. Quartus type and version
Quartus 16.1
Log file is attached.
cfpga.map.err file is empty.
Aneesh
