AD0001
6 years agoHi, While trying to compile the project in Altera_quartus linux environment quartus_map fails abruptly with the following message. > Running quartus_map input in flex scanner failed. What is the reason behind this failure ?
Running quartus_map input in flex scanner failed mv: cannot stat '/home/nis/abd/svn/hw/trunk/pd/fpgas/cfpga/par/cfpga.map.rpt': No such file or directory ERROR: quartus_map exited with Non-Zero ...
SyafieqS
6 years agoHi Aneesh,
May I know following info for better investigation
- OS type and version
- Your machine spec
- Quartus type and version
Can you navigate to this path in your directory /home/nis/abd/svn/hw/trunk/pd/fpgas/cfpga/par/cfpga.map.log and share the log file here and cfpga.map.err as well
