11 years ago
hi! Understanding a coding (counter), help
entity counter is
generic (
n : natural := 4;
port (
clock : in std_logic;
reset_n : in std_logic;
q : out std_logic_vector(n-1 downto 0)
end entity;
architecture rtl of counter is
signal value : std_logic_vector(n-1 downto 0);
begin
process(clock, reset_n)
begin
if (reset_n = ’0’) then
value <= (others => ’0’);
elsif ((clock’event) and (clock = ’1’)) then
value <= value + 1;
end if;
end process;
q <= value;
end rtl;
    It sounds like a homework assignment. It looks like code to me - why not try writing a testbench and simulating it?
    Apparently you want to create a hierarchical design by instantiating the component counter in a top entity. But you don't write a separate entity, instead a second architecture inside the entity counter. This doesn't work.
    Hi, On the 2nd part your are *completely* wrong : you can't use the same entity in the description of THIS entity, It is equivalent to saying "A car is made with a car",
    I recommand port mapping by names, not by position, some thing like this
    my_counter : entity counter
       generic map ( n => 8, k => 4)
       port map (
          clock => KEY(1),
          reset_n => KEY(0),
          Q => Q_int,
          SW => ???,
          KEY => ???,
          LEDR => ???
    LEDR <= Q_int;
    I think that you only have to modify the "rtl" architecture, that what you have done.
    HI!! help please...Why it gives me this error? I want to put a function of k n
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.std_logic_arith.all;
    use ieee.std_logic_signed.all;
    use ieee.numeric_std.all;
    entity contador is
    generic (
    k : natural:= 8;
    n : natural:= LOG2(k+1)--> error (10482): vhdl error at contador.vhd(12): object "log2" is used but not declared
    port
    clock: in std_logic;
    reset_n: in std_logic;
    Q : out std_logic_vector (n-1 downto 0)
    end contador;
    architecture rtl of contador is
    signal clock,reset_n: std_logic;
    signal Q_int: std_logic_vector(n-1 downto 0);
    begin
    PROCESS(clock, reset_n)
    begin
    if (reset_n = '0') then
    Q_int<= (others => '0');
    elsif ((clock'event) and (clock = '1')) then
    if (Q_int<k) then
    Q_int <= Q_int + 1;
    else
    end if;
    end if;
    end process;
    Q <= Q_int;
    end rtl;
    You have no log2 function included - you will need to write one and add it to a package. You will also struggle because you cannot use other generics inside the generic region
    moreover the generic 'k' is not used here. So you can delete it.
    (and give to 'n' the number of bits.)
