PRuz's avatar
PRuz
8 years ago
Hi there, we appear to be having an issue with the following code. Error (10500): (line 88)
LIBRARY  ieee;
USE  ieee.std_logic_1164.all;
LIBRARY  work;
ENTITY  pract3  IS
PORT
	clk      :   IN    STD_LOGIC;
	I_0      :   IN    STD_LOGIC_VECTOR (0 TO 3);
	I_1      :   IN    STD_LOGIC_VECTOR (0 TO 3);
	I_2      :   IN    STD_LOGIC_VECTOR (0 TO 3);
	I_3      :   IN    STD_LOGIC_VECTOR (0 TO 3);
	Oper     :   IN    STD_LOGIC_VECTOR (2  DOWNTO  0);
	act_dis1:   OUT   STD_LOGIC;
	act_dis2:   OUT   STD_LOGIC;
	act_dis4:   OUT   STD_LOGIC;
	act_dis3:   OUT   STD_LOGIC;
	C_out    :   OUT   STD_LOGIC;
	--D         :   OUT   STD_LOGIC_VECTOR (0 TO 1);
	display :   OUT   STD_LOGIC_VECTOR (6  DOWNTO  0);
	oper_led:   OUT   STD_LOGIC_VECTOR (2  DOWNTO  0)
END  pract3;
ARCHITECTURE  bdf_type  OF  pract3  IS
COMPONENT  Practica2
PORT
	clk     : IN  STD_LOGIC;
	I0      : IN  STD_LOGIC_VECTOR (0 TO 3);
	I1      : IN  STD_LOGIC_VECTOR (0 TO 3);
	I2      : IN  STD_LOGIC_VECTOR (0 TO 3);
	I3      : IN  STD_LOGIC_VECTOR (0 TO 3);
	dec     : OUT STD_LOGIC_VECTOR (0 TO 3);
	sal     : OUT  STD_LOGIC_VECTOR (6  DOWNTO  0));
END  COMPONENT;
COMPONENT  arithmetic_circuit
PORT
	C_in   : IN  STD_LOGIC;
	A      : IN  STD_LOGIC_VECTOR (15  DOWNTO  0);
	B      : IN  STD_LOGIC_VECTOR (15  DOWNTO  0);
	S      : IN  STD_LOGIC_VECTOR (1  DOWNTO  0);
	G      : OUT  STD_LOGIC_VECTOR (15  DOWNTO  0)
END  COMPONENT;
COMPONENT  binary_to_bcd
GENERIC
	bits    : INTEGER  := 16;  --bits of the  binary  input
	digits : INTEGER  := 4    --number  of BCD  digits  to  convert  to
PORT
	clk      : IN   STD_LOGIC; --sys clk
	reset_n : IN   STD_LOGIC;
	ena      : IN   STD_LOGIC; --enable
	binary   : IN   STD_LOGIC_VECTOR(bits -1  DOWNTO  0);  --num to  convert
	busy     : OUT  STD_LOGIC; --indicates  conversion  in  progress
	bcd      : OUT  STD_LOGIC_VECTOR(digits *4-1  DOWNTO  0) --BCD  number
END  COMPONENT;
	SIGNAL   A_in :   STD_LOGIC_VECTOR (15  DOWNTO  0);
	SIGNAL   B_in :   STD_LOGIC_VECTOR (15  DOWNTO  0);
	SIGNAL   BCD :   STD_LOGIC_VECTOR (0 TO 15);
	SIGNAL   G :   STD_LOGIC_VECTOR (15  DOWNTO  0);
BEGIN
	oper_led  <= Oper;
	b2v_inst_Practica2 : Practica2
PORT MAP
	clk => clk ,
	dip_1 => BCD(12 TO 15),
	dip_2 => BCD(8 TO 11),
	dip_3 => BCD(4 TO 7),
	dip_4 => BCD(0 TO 3),
	dec_D0 => act_dis1 ,
	dec_D1 => act_dis2 ,
	dec_D2 => act_dis3 ,
	dec_D3 => act_dis4 ,
	--D => D,
	sal => display
PORT MAP
	C_in => Oper(2),
	A => A_in ,
	B => B_in ,
	S => Oper(1  DOWNTO 0),
	C_out => C_out,
	G => G
	stbin : binary_to_bcd
PORT MAP
	CLK => clk ,
	reset_n => ’1’,
	ena => ’1’,
	binary => G,
	bcd => BCD
	A_in(7  DOWNTO  4)  <= I_0;
	A_in(3  DOWNTO  0)  <= I_1;
	B_in(7  DOWNTO  4)  <= I_2;
	B_in(3  DOWNTO  0)  <= I_3;
	A_in (8)   <=   ’0’;
	A_in (9)   <=   ’0’;
	A_in (10)  <=  ’0’;
	A_in (11)  <=  ’0’;
	A_in (12)  <=  ’0’;
	A_in (13)  <=  ’0’;
	A_in (14)  <=  ’0’;
	A_in (15)  <=  ’0’;
	B_in (8)   <=  ’0’;
	B_in (9)   <=  ’0’;
	B_in (10)  <=  ’0’;
	B_in (11)  <=  ’0’;
	B_in (12)  <=  ’0’;
	B_in (13)  <=  ’0’;
	B_in (14)  <=  ’0’;
END  bdf_type;
The error we're getting is:
Error (10500): VHDL syntax error at pract3.vhd(88) near text "PORT"; expecting "end", or "(", or an identifier ("port" is a reserved keyword), or a concurrent statement
  • Tricky's avatar
    Tricky
    You have a port map with no label or entity name
  • PRuz's avatar
    PRuz
    Thank you so much for your help, but we're not quite sure what you mean. Also, why are we getting the error on the second PORT MAP but not on the first? Thanks once again :)
  • Tricky's avatar
    Tricky
    Line 88, you have a port map without specifying what component you're actually port mapping
