PRuz
8 years agoHi there, we appear to be having an issue with the following code. Error (10500): (line 88)
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY work;
ENTITY pract3 IS
PORT
clk : IN STD_LOGIC;
I_0 : IN STD_LOGIC_VECTOR (0 TO 3);
I_1 : IN STD_LOGIC_VECT...
PRuz
8 years agoThank you so much for your help, but we're not quite sure what you mean. Also, why are we getting the error on the second PORT MAP but not on the first? Thanks once again :)
