Hi there, I just installed baseline 10.2 and acquired a licensing file based on the Host ID (physical address using ipconfig /all). When trying to open my .gfd file, I get the message below:
Network licensing error: the maxplus2web feature [my ID] but this machine's host ID is "000000000"
Anything I can do? OS is Windows XP on an old HP desktop (my only PC that still has a parallel port...).
I tried to modify the licensing file putting zeroes instead of my number but no luck.
Cheers,
Kurt
Cheers,
Kurt
- AR_A_Intel
Hello
Welcome to INTEL forum. May I know? Do you have the license.dat file. To narrow down this issue, can you please provide me the latest of the following?
1) license.dat file
You can also reply/attach your file in private message.
- KEbre
Thanks so much for your quick reply. I attached the license.dat file to this message. As the message system didn't allow me to attach a .dat file, I changed the file extension to txt.
Cheers,
Kurt
- KEbre
Hi again,
In the meantime I had a new license file generated using "000000000000" as Host ID - and it works!
Thanks again!
Kurt
- AR_A_Intel
Thanks for update
