MSura2
6 years agoHi, I'm having some issues with regards to running the examples for the HLS compiler 18.1. I've installed all the prerequisites are expected and I'm just running the simple demo for counter and the error I'm getting is shown below:
COMMAND: make test-x86-64 ERROR: i++ counter.cpp -march=x86-64 -o test-x86-64 error: unable to open output file 'counter4716.o': 'Error opening output file 'counter4716.o'' 1 error generated. ...
AnilErinch_A_Intel
6 years agoHi
You can try using an older version of Ubuntu and a supported version gcc , and that should solve the problem.
There are some methods available online to use the older gcc on newer OS versions.
For supported gcc versions , you can refer to the document for HLS compiler version 18.1
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn-hls-18-1.pdf
Thanks and Regards
Anil
