MSura2
6 years agoHi, I'm having some issues with regards to running the examples for the HLS compiler 18.1. I've installed all the prerequisites are expected and I'm just running the simple demo for counter and the error I'm getting is shown below:
COMMAND: make test-x86-64 ERROR: i++ counter.cpp -march=x86-64 -o test-x86-64 error: unable to open output file 'counter4716.o': 'Error opening output file 'counter4716.o'' 1 error generated. ...
AnilErinch_A_Intel
6 years agoHi
Please let us know which OS version you are using and can you use another version of gcc and try reproducing the issue.
Thanks and Regards
Anil.
MSura2
6 years agoHi Anil,
I've also seemed to find something relevant, whereby the installation guides you to use only gcc 4.4.7 compilers, but since they are back dated now is it possible to use a new compiler and could you tell me which one would be valid for the HLS Compiler version 18.1.
Mayank
