Hi, I'm having some issues with regards to running the examples for the HLS compiler 18.1. I've installed all the prerequisites are expected and I'm just running the simple demo for counter and the error I'm getting is shown below:
Hi ,
Can you include the path to your include directory also like shown below, and also include additional compiler options
as given below and let us know the results.
i++ -I/home/YourPath/intelFPGA/18.1/hls/include --fpc --fp-relaxed --debug-log -v -march=x86-64 counter.cpp -o test-x86-64
Please try to run it from the terminal without including in the makefile , i.e directly and also including in the makefile. Please let us know the results of each.
Thanks and Regards
Anil
- MSura26 years ago
As requested I ran the command that you suggested with the given options and this is the result.
i++ -I/opt/intelFPGA/18.1/hls/include --fpc --fp-relaxed --debug-log -v -march=x86-64 counter.cpp -o test-x86-64
Target FPGA part name: 10AX115U1F45I1SG
Target FPGA family name: Arria 10
Target FPGA speed grade: -1
Analyzing counter.cpp
In file included from counter.cpp:1:
In file included from /opt/intelFPGA/18.1/hls/include/HLS/hls.h:11:
In file included from /opt/intelFPGA/18.1/hls/include/HLS/hls_internal.h:5:
In file included from /usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/queue:59:
In file included from /usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/deque:59:
/usr/lib/gcc/x86_64-linux-gnu/7.5.0/../../../../include/c++/7.5.0/bits/stl_algobase.h:59:10: fatal error:
'bits/c++config.h' file not found
#include <bits/c++config.h>
1 error generated.
HLS x86-64 compile FAILED.
I'm not sure about this issue and I've tried to google for it but it's not fixing the issue. Do you have any suggestions?
regards,
Mayank
