Hi, I can,t install the fpga quartus prime lite version 18.1 on my windows 10-hardware(C-disk) .The information I got is that : Windows 10 Can't handle the .qdz-files that fpga quartus is saved in + that windows 10 isn't compatible with this files
Hi Eje,
1. Open new incognito tab from Chrome
2. Go to http://fpgasoftware.intel.com/ and select 18.1 lite
3. Select one of the installer files required to download (MAX 10 FPGA device support)
4. Click “Download Selected Files” button
5. The page will get redirect to Intel FPGA Program login page, LINK.
6. Login
1. If successfully authentication, it will auto-redirect you back to “ http://fpgasoftware.intel.com ” (Please ignore the login panel on your top right, it will still showing Sign In)
1. Repeat step 3 and 4
2. Download process will be proceed, start download the file.
3. Done, you have access to it
2. Else, it will stay at Intel FPGA Program login page and if you are getting error message :” Username and Password Incorrect” than please reset the password and follow this format - use just alphanumeric characters and just one special character - either @ or $, something similar to intel@123. Please do not use other special characters like ‘&’ . Once you are done resetting the password repeat the steps 1-6 mentioned above.
- ELind176 years ago
Thanx again I Will try this!!! All the best ????
