Hi, Have been able to add the qsys ADC module to the project but on final compilation the flow summary reports 0/1 ADC blocks in use even after I have selected all ports ANA1IN1 to ADC1IN8 in the qsys window.
- 6 years ago
Hello there ,
Here attached the screen shot and the modfied design file with ADC block utilization mentioned in the compliation report.
As of understood from the design you provided , quartus is optimizing the ADC block since it is no where used in the design.
In the modified design i instantiated the ADC input and clock as Input port which restrict the quartus to optimize the same.
Hope helps ,
Thank you ,
Sree
Hello , I thought i attached the file to you , Sorry looks i missed out, Can i know you still facing the same issue ? if yes , i will look at again .
- AKohl36 years ago
I am still facing the same problem. I have been able to check the ADC input if I invoke the Jtag avalon adapter but if I use just the ADC control core the response data is stuck at zero. In the attached project I am trying a simple led blink check using the output of the ADC module. I would really appreciate a prompt reply.
