14 years ago
hey experienced members Plz help me?
My project is: design and test 4X4 bit unsigned multiplier using right shift add algorithm
With little knowledge about VHDL
One friend Kaz has helped me write the code.but I dont understand completely. Can you explain it to me?
here is the code that I get troubles:
architecture rtl of mult1 is
signal shift_reg1 : std_logic_vector(3 downto 0) := "0000";
signal shift_reg2 : std_logic_vector(7 downto 0) := x"00";
signal reg1 : std_logic_vector(7 downto 0);
signal opA : std_logic_vector(3 downto 0);
begin
R <= shift_reg2(0);
reg1(7 downto 3) <= std_logic_vector(resize(unsigned(OpA),5) + unsigned(shift_reg2(7 downto 4)));
reg1(2 downto 0) <= shift_reg2(3 downto 1);
what's the three signals shift-reg1,shift-reg2,reg1( they are the singals between?) what does shift-reg2(0) mean?
Is it nessecary to write :="0000" and :=x"00" at the signal shift-reg1,2
(My teacher dont write them in the signal declaration)
and the next code I almost don't understand ( other ways to write them easier to understand??).
I have added the diagram of the algorithm and the whole code( helped by Kaz) underneath.
Looking forward to hearing from you soon.;)
1 Reply
    --- Quote Start ---
    begin
    R <= shift_reg2(0);
    --- Quote End ---
    shift_reg1 corresponds to your 4 bit shift reg of multiplier.
    shift_reg2 is your second 8 bit register right at product output.
    reg1 is the other 8 bit register at top of your diagram
    --- Quote Start ---
    --- Quote End ---
    1st lsb of that register i.e. bit index 0
    --- Quote Start ---
    --- Quote End ---
    no, but if you go to modelsim you will get some undefined initial values.
    --- Quote Start ---
    --- Quote End ---
    you can use an adder directly instead of addition statement. go to megawizard(tools menu) and let quartus create an adder then you need to connect as 4 bits , 4 bits inputs and 5 bits output.
    the shifting itself can be done through megawizard as well.
