12 years ago
Help with test bench error message
Hi, I'm new to vhdl and trying to simulate a counter from 0 to 3 using integers. The code that I used for the module is below
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Counter is
Port(clk : in STD_LOGIC;
Reset : in STD_LOGIC;
Count : out integer;
Carry : out STD_LOGIC);
end Counter;
architecture Behavioral of Counter is
signal count_int : integer;
begin
process (reset, clk)
begin
if reset = '1' then
count_int <= 0;
carry <= '0';
elsif clk'event and clk = '1' then
if count_int <= 2 then
count_int <= count_int + 1;
carry <= '0';
else -
count_int <= 0;
carry <= '1';
end if;
end if;
end process;
count <= count_int;
end Behavioral;
The test bench that I used is below
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY TB_Counter IS
END TB_Counter;
ARCHITECTURE behavior OF TB_Counter IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT Counter
    PORT(
         clk : IN  std_logic;
         Reset : IN  std_logic;
         Count : OUT  integer;
         Carry : OUT  std_logic
    END COMPONENT;
   --Inputs
   signal clk : std_logic := '0';
   signal Reset : std_logic := '0';
  --Outputs
   signal Count : integer;
   signal Carry : std_logic;
   -- Clock period definitions
   constant clk_period : time := 50 us;
BEGIN
 -- Instantiate the Unit Under Test (UUT)
   uut: Counter PORT MAP (
          clk => clk,
          Reset => Reset,
          Count => Count,
          Carry => Carry
   -- Clock process definitions
   clk_process :process
   begin
  clk <= '0';
  wait for clk_period/2;
  clk <= '1';
   end process;
   -- Stimulus process
   stim_proc: process
   begin
 reset => '0';
 wait for 3 ns;
 reset => '1';
 wait for 3 ns;
 reset => '0';
 wait;
   end process;
END;
I am using ISE Project navigator and when I try to simulate the test bench I am getting these errors
 ERROR:HDLCompiler:806 - "C:/Users/Alex/Desktop/VHDL/counter_03/TB_Counter.vhd" Line 88: Syntax error near "=>".
ERROR:HDLCompiler:806 - "C:/Users/Alex/Desktop/VHDL/counter_03/TB_Counter.vhd" Line 90: Syntax error near "=>".
ERROR:HDLCompiler:806 - "C:/Users/Alex/Desktop/VHDL/counter_03/TB_Counter.vhd" Line 92: Syntax error near "=>".
WARNING:HDLCompiler:1369 - "C:/Users/Alex/Desktop/VHDL/counter_03/TB_Counter.vhd" Line 85: Possible infinite loop; process does not have a wait statement
ERROR:HDLCompiler:854 - "C:/Users/Alex/Desktop/VHDL/counter_03/TB_Counter.vhd" Line 39: Unit <behavior> ignored due to previous errors.
Can someone advice me on what I am doing wrong and how can I amend it, thanks in advance.
    Wow, I did not even realise that, thank you.
    --- Quote Start ---
    simple,
    reset <= '0'; (you have written reset => '0')
    at the end
    --- Quote End ---
