12 years ago
help with counter
im trying to learn to create counter that starts counting based on the input that from the expansion after i compile it it seems an error occur and i dont know how to solve it. help me guys.. this error occured (Error (10500): VHDL syntax error at ledwithcounter.vhd(29) near text "then"; expecting ":=", or "<=") ....here i attach my program.. help me guys..
Library IEEE;
use ieee.std_logic_1164.all;
use ieee.numeric_unsigned.all;
entity GPIOwithLED is
port( GPIO_0 : in std_logic_vector(1 downto 0);
ld_enb : in std_logic;--parallel load enable,active high
clk : in std_logic;-- system clock
cnt_enb : in std_logic;--count enable, active high
rst_n : in std_logic;-- reset,active high
q : out std_logic_vector(1 downto 0));
end GPIOwithLED ;
architecture bufferwithGpio_arc of GPIOwithLED is
begin
process(GPIO_0)
begin
if (GPIO_0(0)='1') then q<=GPIO_0(1 downto 0);
else q<= "00";
end if;
end process;
counter:process(clk,rst_n) is
begin
if ( rst_n='0' ) then
count <=(others=>'0');
else(clk'event and Clk ='1')then
if (ld_enb='1')then
count<=GPIO_0;
elsif(cnt_enb ='1')then
count <=count+1;
end if;
end if;
end process counter;
-- assigment ouput
q <= count;
end bufferwithGpio_arc;
    I don't know what your plans are but sounds ok to me to use a 50MHz clock and manual pushbutton reset as long as it is suitable to your case!! Try and learn. All of us play with code until it works. If it doesn't you are in trouble.
    Help with counter
    library ieee;
    use ieee.numeric_std.all;
    use ieee.std_logic_unsigned.all;
    entity AcounterGpio2 is
    port( PIRin : in std_logic;
    clk : in std_logic;
    reset : in std_logic;
    PIRout : out std_logic;
    q : out std_logic);
    end AcounterGpio2 ;
    architecture bufferwithGpio_arc of AcounterGpio2 is
    signal cnt,enable: std_logic;
    begin
    process(PIRin)
    begin
    if PIRin = '1' then
    PIRout <= PIRin ;
    else PIRout <= '0';
    end if;
    end process;
    counter:process (clk)
    enable <= PIRout;
    begin
    if (rising_edge(clk)) then
    if reset = '1' then
    cnt := 0;-- Reset the counter to 0
    elsif enable = '1' then
    cnt := cnt + 1;-- Increment the counter if counting is enabled
    end if;
    end if;
    -- Output the current count
    q <= cnt;
    error Error (10500): VHDL syntax error at AcounterGpio2.vhd(29) near text "enable"; expecting "begin", or a declaration statement keep showing up.. what should i do and how do i declare the output from PIRout that will be the input for my counter.
    First get rid of the ieee.std_logic_unsigned.all; and use unsigned and signed types, as suggested before. Second you can to signal assignments just after the process line. it needs to be after the "begin".
