Help with counter
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity AcounterGpio2 is
port( PIRin : in std_logic;
clk : in std_logic;
reset : in std_logic;
PIRout : out std_logic;
q : out std_logic);
end AcounterGpio2 ;
architecture bufferwithGpio_arc of AcounterGpio2 is
signal cnt,enable: std_logic;
begin
process(PIRin)
begin
if PIRin = '1' then
PIRout <= PIRin ;
else PIRout <= '0';
end if;
end process;
counter:process (clk)
enable <= PIRout;
begin
if (rising_edge(clk)) then
if reset = '1' then
cnt := 0;-- Reset the counter to 0
elsif enable = '1' then
cnt := cnt + 1;-- Increment the counter if counting is enabled
end if;
end if;
-- Output the current count
end process counter;
q <= cnt;
end bufferwithGpio_arc;
error Error (10500): VHDL syntax error at AcounterGpio2.vhd(29) near text "enable"; expecting "begin", or a declaration statement keep showing up.. what should i do and how do i declare the output from PIRout that will be the input for my counter.
