13 years agohelp with counter
im trying to learn to create counter that starts counting based on the input that from the expansion after i compile it it seems an error occur and i dont know how to solve it. help me guys.. this error occured (Error (10500): VHDL syntax error at ledwithcounter.vhd(29) near text "then"; expecting ":=", or "<=") ....here i attach my program.. help me guys..
Library IEEE; use ieee.std_logic_1164.all; use ieee.numeric_unsigned.all; entity GPIOwithLED is port( GPIO_0 : in std_logic_vector(1 downto 0); ld_enb : in std_logic;--parallel load enable,active high clk : in std_logic;-- system clock cnt_enb : in std_logic;--count enable, active high rst_n : in std_logic;-- reset,active high q : out std_logic_vector(1 downto 0)); end GPIOwithLED ; architecture bufferwithGpio_arc of GPIOwithLED is begin process(GPIO_0) begin if (GPIO_0(0)='1') then q<=GPIO_0(1 downto 0); else q<= "00"; end if; end process; counter:process(clk,rst_n) is begin if ( rst_n='0' ) then count <=(others=>'0'); else(clk'event and Clk ='1')then if (ld_enb='1')then count<=GPIO_0; elsif(cnt_enb ='1')then count <=count+1; end if; end if; end process counter; -- assigment ouput q <= count; end bufferwithGpio_arc;
